Portable Debotnet v.0.6.7
  • הורדה | Portable Debotnet v.0.6.7
    תוכנה חינמית ונישאת (לא דורשת התקנה), לניהול ושמירה על הפרטיות בחלונות 10
    סרטון הדרכה על התוכנה:
    https://youtu.be/71d-tjyEsJ8
    The most important features at a glance
    • Disable telemetry and online features, which send your data (sensitive and not) to Microsoft
    • Choose which unwanted functions you wish to disable
    • Uninstall Windows 10’s Built-in Apps
    • Debotnet will show you what it's doing. You have full control, because the executing code can be viewed in a simple text editor
    • Debug mode. E.g. the Test mode lets you see which values are twisted in registry or commands executed
    • Simple scripting engine for adding custom privacy rules
    • Scripts updated on GitHub
    • Support for Ninite service, which allows you to download and install more than 70 popular apps for Windows.
    • Download Windows 10 ISO files using Microsoft Media Creation Tool with command line switches and also through MCT Wrapper
    • Download deprecated Windows apps, e.g. Classic Calculator
    • Modern and familiar UI, with theme support
    • Small footprint. No installation required (Portable)
    • 100% Free Software (License)
    תיהנו.
    נערך לאחרונה על ידי P--L; 16.03.20, 23:03.
