מבוסס על הרכבת מודולים ויזואליים מוכנים מראש כמו בהרכבת תצרף.
לא ניסיתי
לא ניסיתי
App Builder is a complete visual environment that allow us to create, with or without programming knowledge, HTML5 and hybrid applications for the web and mobile devices.
Visual designer
App Builder provide us dozens of visual and no visual controls ready to be placed in the application's designer. Simply drag and drop the control that you need into the designer and then place it where you wanted.
Visual actions
You don't need to know Javascript to create applications with App Builder. The App Builder's script lenguage are based in hundreds of visual actions that you can simply put in the place that you need to be executed.
Extensible
The App Builder's applications can be extended using Javascript in addition to the visual actions provided by the program. Also it's possible to use App Builder's Javascript plugins and Apache Cordova™ plugins.
Apache Cordova™
Talking about Apache Cordova™, App Builder prepare the appropiate configuratoin file as well BAT files ready to be executed to compile our applications for Android™ and other supported platforms.
App Builder CLI
App Builder include a command line compiler in addition with the visual environment. In this way we can compile our applications from the command line, simply and fast.
And many more...
App Builder is a complete development environment. Can creates HTML5 applications ready to be executed in desktop and mobile browsers. In addition with Apache Cordova™, we have all the required stuff to create applications to other platforms like Android™.
Visual designer
Visual actions
Extensible
Apache Cordova™
App Builder CLI
And many more...
App Builder 2020.70 (x64)
116.65 מ"ב
116.65 מ"ב
