Ksnip 1.7.0 - לכידת מסך עם אפשרות להוספת הערות
  • הורדה | Ksnip 1.7.0 - לכידת מסך עם אפשרות להוספת הערות
    Ksnip 1.7.0
    תוכנה ללכידת מסך, או חלק ממנו עם אפרות להוספת הערות ואיורים.
    Latest ksnip version contains following features:
    • Supports Linux (X11, KDE Wayland and Gnome Wayland), Windows and MacOS.
    • Taking screenshot of a custom rectangular area that can be drawn with mouse cursor.
    • Taking screenshot of last selected rectangular area without selecting again.
    • Taking screenshot of the screen/monitor where the mouse cursor is currently located.
    • Taking screenshot of full screen, including all screens/monitors.
    • Taking screenshot of window that currently has focus.
    • Taking screenshot of window under mouse cursor.
    • Take screenshot with or without mouse cursor.
    • Capture mouse cursor as annotation item that can be moved and deleted.
    • Customizable capture delay for all capture options.
    • Upload screenshots directly to imgur.com in anonymous or user mode.
    • Upload screenshots via custom user defined scripts.
    • Command line support, for taking screenshot and saving it to default location, filename and format.
    • Filename wildcards for Year ($Y), Month ($M), Day ($D), Time ($T) and Counter (multiple # characters for number with zero leading padding).
    • Print screenshot or save is to pdf/ps.
    • Annotate screenshots with pen, marker, rectangles, ellipses, texts and other tools.
    • Annotate screenshots with stickers and add custom stickers.
    • Add watermarks to captured images.
    • Global HotKeys for taking Screenshots (Currently only for Windows and X11).
    • Tabs for Screenshots and images.
    • Open existing images via dialog, drag-and-drop or paste from clipboard.
    • Run as single instance application (secondary instances send cli parameter to primary instance).
    • Many configuration options.
    התוכנה חינמית בקוד פתוח.
    תיהנו.
    Ksnip is a Qt based cross-platform screenshot tool that provides many annotation features for your screenshots. - ksnip/ksnip
