Portable Windows System Control Center v.4.0.5.3
התוכנה ניועדת לסייע בהתקנת חבילות של אפליקציות מהמקורות:
WSCC allows you to install, update, execute and organize the utilities from various system utility suites. WSCC can install and update the supported utilities automatically. Alternatively, WSCC can use the http protocol to download and run the programs. The portable edition doesn't require installation and can be run directly from a USB drive.
WSCC supports the following major utility suites:
- Sysinternals Suite is property of Microsoft Corporation
Sysinternals Suite download and Licensing FAQ website.
NirSoft Utilities is property of Nir Sofer
NirSoft Utilities website.
תוכנה נישאת, חינמית לשימוש אישי.
