Portable Optimizer 5.0- למיטוב המערכת
  • הורדה | Portable Optimizer 5.0- למיטוב המערכת
    תוכנה נשאת (ללא התקנה) , קלת משקל פחות מ- 2MB , שנכתבה בקוד פתוח, והמיועדת למיטוב המערכת.
    Summary:
    Portable utility that helps you to restore your privacy and increase your security.
    Optimizer is recommended after a fresh, clean installation of Windows to achieve maximum privacy and security.
    Depending on your version of Windows, Optimizer will also allow you to perform some specific tweaks.
    Features:
    • Speed up your system and network performance
    • Disable unnecessary Windows services
    • Disable Windows telemetry
    • Disable Office telemetry (works only with 2016)
    • Disable Cortana
    • Disable Windows 10 automatic updates
    • Uninstall UWP apps
    • Clean up your system drive
    • Fix common registry issues
    • Remove unwanted programs running at startup
    • Change Microsoft Edge download folder
    • Edit your hosts file
    • Add items in desktop right-click menu
    • Define custom commands for run dialog
    • Supports silent run using configuration file
    קישור להורדה: https://github.com/hellzerg/optimizer
    תוכנה חינמית, תיהנו
    Make Windows faster and more secure. Contribute to hellzerg/optimizer development by creating an account on GitHub.
    תודה דניאל ישר כוח
