ImageMagick 7.0.10-60 x64- תוכנה לטיפול במדיה גרפית
  • ImageMagick 7.0.10-60 x64- תוכנה לטיפול במדיה גרפית
    תוכנה למשתמשי תוכנות גרפיות. החבילה כוללת אפשרות ליצור, לערוך, לעצב ולהמיר קבצי גרפיקה.
    ImageMagick Features:
    • Format conversion: convert an image from one format to another (e.g., PNG to JPEG).
    • Transform: resize, rotate, crop, flip or trim an image.
    • Transparency: render portions of an image invisible.
    • Draw: add shapes or text to an image.
    • Decorate: add a border or frame to an image.
    • Special effects: blur, sharpen, threshold, or tint an image.
    • Animation: create a GIF animation sequence from a group of images.
    • Text & comments: insert descriptive or artistic text in an image.
    • Image identification: describe the format and attributes of an image.
    • Composite: overlap one image over another.
    • Montage: juxtapose image thumbnails on an image canvas.
    • Generalized pixel distortion: correct for or induce image distortions, including perspective.
    • Morphology of shapes: extract features, describe shapes, and recognize patterns in images.
    • Motion picture support: read and write the common image formats used in digital film work.
    • Image calculator: apply a mathematical expression to an image or image channels.
    • Discrete Fourier transform: implements the forward and inverse DFT.
    • Color management: accurate color management with color profiles or instead of-- built-in gamma compression or expansion as demanded by the color space.
    • High dynamic-range images: accurately represent the wide range of intensity levels found in real scenes ranging from the brightest direct sunlight to the deepest darkest shadows.
    • Encipher or decipher an image: convert ordinary images into unintelligible gibberish and back again.
    • Virtual pixel support: convenient access to pixels outside the image region.
    • Large image support: read, process, or write mega-, giga-, or tera-pixel image sizes.
    • Threads of execution support: ImageMagick is thread-safe, and most internal algorithms execute in parallel to take advantage of speed-ups offered by multicore processor chips.
    • Distributed pixel cache: offload intermediate pixel storage to one or more remote servers.
    • Heterogeneous distributed processing: certain algorithms are OpenCL-enabled to take advantage of speed-ups offered by executing in concert across heterogeneous platforms consisting of CPUs, GPUs, and other processors.
    • ImageMagick on the iPhone: Convert, edit, or compose images on your iOS computing device such as the iPhone or iPad.
    תוכנה חינמית,
    תיהנו.
    Use ImageMagick® to create, edit, compose, and convert bitmap images. Resize an image, crop it, change its shades and colors, add captions, and more.
