CCleaner Standard v.5.88.9346
שוחררה גרסה חדשה של התוכנה הותיקה והיעילה לניקוי המחשב והאצת ביצועיו. מעל מליון הורדות.......
מאפיינים עיקריים:
CCleaner uses the same familiar three-tab interface it always has, with the first tab showing you the main choices, including Cleaner, Registry, Tools, and Options. The second tab lets you choose any settings before you run it. The third tab shows you what is happening and what was done.
The drive cleaner and registry cleaner are both conservatives. There are drive cleaners out there that can clear more space if needed, but they aren't as safe as CCleaner. While we don't recommend cleaning your registry, again, CCleaner is very conservative, and I've never had an issue after thousands of uses.
Under Tools, you can find many other tools to clean and speed up your PC more. There's an uninstaller, startup manager, browser plugin manager, system restore and drive wiper. It also has a disk analyzer to see where space is being wasted and a duplicate file finder.
Finally, many more options allow you to whitelist cookies, include or exclude files or folders, monitoring, and more.
תוכנה חינמית, ( יש גם גרסאות מורחבות יותר בתשלום).
תיהנו.
מאפיינים עיקריים:
תיהנו.
